Panel prep getting ready to start wiring. Lots of little things to get done since when the wiring starts, the panel will, more or less, be in for good. All the instrument boxes are mounted behind the panel and on the firewall. The only box not mounted is the backup battery. I have not decided on the best place since I would like to give it some support from below as it's about 2.5lbs.
